跳转到主内容
How to open up a Nokia N9
你所需要的
  1. How to open up a Nokia N9, remove top parts: 步骤 1 中的图像 1,3 How to open up a Nokia N9, remove top parts: 步骤 1 中的图像 2,3 How to open up a Nokia N9, remove top parts: 步骤 1 中的图像 3,3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. How to open up a Nokia N9, loosen the screen: 步骤 2 中的图像 1,3 How to open up a Nokia N9, loosen the screen: 步骤 2 中的图像 2,3 How to open up a Nokia N9, loosen the screen: 步骤 2 中的图像 3,3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. How to open up a Nokia N9, disconnect screen from phone: 步骤 3 中的图像 1,3 How to open up a Nokia N9, disconnect screen from phone: 步骤 3 中的图像 2,3 How to open up a Nokia N9, disconnect screen from phone: 步骤 3 中的图像 3,3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
结论
另外一个人完成了本指南。
knipwim
于09/01/18注册
11,311 声望
创作了36篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 56
总计 1,949
