跳转到主内容
How to open the SteelSeries Nimbus+ Controller
你所需要的
  1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: 步骤 1 中的图像 1,2 How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: 步骤 1 中的图像 2,2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: 步骤 2 中的图像 1,1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: 步骤 3 中的图像 1,1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 步骤 4 中的图像 1,2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 步骤 4 中的图像 2,2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 步骤 5 中的图像 1,2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 步骤 5 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 步骤 6 中的图像 1,2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: 步骤 6 中的图像 2,2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 步骤 7 中的图像 1,2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: 步骤 7 中的图像 2,2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 步骤 8 中的图像 1,3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 步骤 8 中的图像 2,3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: 步骤 8 中的图像 3,3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 步骤 9 中的图像 1,3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 步骤 9 中的图像 2,3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: 步骤 10 中的图像 1,1
    • Remove the back cover assembly.
结论
另外一个人完成了本指南。
Adriana Zwink
于12/18/19注册
62,229 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 42
总计 1,822
