跳转到主内容
How to open the Flipper Zero
你所需要的
    • Go to Main Menu > Settings > Power.
    • Select Power OFF.
    • Alternatively, you can press and hold the Back-button for around 10 seconds.
    • Confirm by pressing the Right-button.
  1. How to open the Flipper Zero, Remove the microSD card: 步骤 2 中的图像 1,1
    • Eject the microSD card by pressing it with your fingernail.
  2. How to open the Flipper Zero, Remove the screws: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  3. How to open the Flipper Zero, Open the back cover: 步骤 4 中的图像 1,3 How to open the Flipper Zero, Open the back cover: 步骤 4 中的图像 2,3 How to open the Flipper Zero, Open the back cover: 步骤 4 中的图像 3,3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
结论
2等其他人完成本指南。
Sebastian
于08/19/18注册
31,055 声望
创作了71篇指南
1指南评论
Amazing, this was super helpful, thank you for doing this amazing person!
Filiz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 3,123
