简介
When you want to clean the inside of sawdust, or replace a part, you will need to open up the jigsaw. This guide will not only show how to open it, but also which specific steps are needed to close it again.
  1. Make sure the jigsaw is unplugged. Unscrew the bolt holding the guide plate to the jigsaw.
    • Make sure the jigsaw is unplugged.
    • Unscrew the bolt holding the guide plate to the jigsaw.
    • Unscrew the 10 screws holding the 2 frame halves together.
  2. Separate the 2 halves by slowly prying them apart, going around the edges evenly. When separated, take care of some loose parts.
    • Separate the 2 halves by slowly prying them apart, going around the edges evenly.
    • When separated, take care of some loose parts.
      • The nut holding the guide plate bolt.
      • Piece of plastic holding some cables.
      • Metal strip pushing the blade back.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts. Then, make sure the right parts line up and are fitted correctly:
    • Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts.
    • Then, make sure the right parts line up and are fitted correctly:
      • The holes for the blade holder. The axis is located on the other halve.
      • The blade driver.
      • The blade guide.
      • The metal strip.
  5. Now, add the empty halve on top of the halve containing the parts.
    • Now, add the empty halve on top of the halve containing the parts.
    • Screw everything back together.
终点
knipwim
于2018年09月01日注册
986 信誉积分
创作了9篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 23
总计 65
