跳转到主内容
How to mend a hitch in an almost invisible way
你所需要的
  1. How to mend a hitch in an almost invisible way, How to mend a hitch in an almost invisible way: 步骤 1 中的图像 1,2 How to mend a hitch in an almost invisible way, How to mend a hitch in an almost invisible way: 步骤 1 中的图像 2,2
    • To mend a hitch, you only need a few accessories: thermo-sticky cloth, an iron, wire, a needle, a pair of scissors and ... a little patience!
    • It is better to wash the piece of clothing first. Thus, the glue will adhere better to the fabric.
    • Iron the hole to flatten the edges and cut any excess wires to get clean, sharp edges.
  2. How to mend a hitch in an almost invisible way: 步骤 2 中的图像 1,2 How to mend a hitch in an almost invisible way: 步骤 2 中的图像 2,2
    • Cut the thermo-adhesive fabric to the correct size. The piece should be slightly larger than the hitch.
    • Round off the corners as sharp angles may cause the patch to peal off more easily.
  3. How to mend a hitch in an almost invisible way: 步骤 3 中的图像 1,2 How to mend a hitch in an almost invisible way: 步骤 3 中的图像 2,2
    • Lay the canvas side glue (this is the brightest side) on the wrong side of the fabric.
    • Secure it with the iron by pressing firmly on the iron and making it move back and forth and rotate.
    • Read carefully the garment label and the instructions for use of the thermo-adhesive fabric. Follow the instructions for iron temperature and ironing time. Otherwise you risk burning the fabric and / or the thermo-adhesive fabric.
  4. How to mend a hitch in an almost invisible way: 步骤 4 中的图像 1,3 How to mend a hitch in an almost invisible way: 步骤 4 中的图像 2,3 How to mend a hitch in an almost invisible way: 步骤 4 中的图像 3,3
    • The canvas is now glued, but to make sure it does not peel off after a few washes, it is better to sew the edge to the fabric.
    • Choose a colored thread close to that of the fabric so that the seam is seen as little as possible.
    • Thread the thread on a needle and tie a knot at the end.
    • Starting from the wrong side of the fabric (so that the knot does not appear), sew the needle on both sides of the fabric along the edge of the piece of fabric.
    • I prefer to work here on the place of the fabric to better control the visibility of the points.
    • Once arrived at the end, make a knot again and cut the excess thread. There you go ! We see almost nothing!
    • Who has a sewing machine, can obviously use it during this stage. But it's just as easy to hand :)
结论
Admire your work and put on your favorite skirt / pants / shirt / tee shirt!
3等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Claire Miesch
于10/25/16注册
175,372 声望
撰写一个指南
团队
iFixit EU Team iFixit EU Team 的会员
Staff
37 名成员
创作了1,205篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 102
过去 30 天: 566
总计 70,223
