跳转到主内容
How to lubricate the HP Photosmart c4780 printhead track
你所需要的
  1. How to lubricate the HP Photosmart c4780 printhead track, Outer Shell Disassembly: 步骤 1 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track, Outer Shell Disassembly: 步骤 1 中的图像 2,2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. How to lubricate the HP Photosmart c4780 printhead track: 步骤 2 中的图像 1,1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. How to lubricate the HP Photosmart c4780 printhead track: 步骤 3 中的图像 1,1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. How to lubricate the HP Photosmart c4780 printhead track: 步骤 4 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track: 步骤 4 中的图像 2,2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. How to lubricate the HP Photosmart c4780 printhead track: 步骤 5 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track: 步骤 5 中的图像 2,2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. How to lubricate the HP Photosmart c4780 printhead track: 步骤 6 中的图像 1,1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. How to lubricate the HP Photosmart c4780 printhead track: 步骤 8 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track: 步骤 8 中的图像 2,2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. How to lubricate the HP Photosmart c4780 printhead track: 步骤 9 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track: 步骤 9 中的图像 2,2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. How to lubricate the HP Photosmart c4780 printhead track: 步骤 10 中的图像 1,1
    • Pull the printer hood upward.
  10. How to lubricate the HP Photosmart c4780 printhead track, How to lubricate the HP Photosmart c4780 printhead track: 步骤 11 中的图像 1,2 How to lubricate the HP Photosmart c4780 printhead track, How to lubricate the HP Photosmart c4780 printhead track: 步骤 11 中的图像 2,2
    • Carefully, apply a small amount of grease to the metallic printhead track.
    • You can either use your bare finger or wear a latex glove when applying the grease.
    • The grease will reduce the friction between the track and the printhead, improving mobility.
结论
To put the printer back together, follow these instructions in reverse order.
4等其他人完成本指南。
Renee Lamb
于09/26/12注册
235 声望
创作了3篇指南
团队
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G11
4 名成员
创作了6篇指南
一条评论
The question is how to clean the Printer Head, unfortunately the site refers you to this page which deals with lubricating the track. It does not address the cleaning question or provide any guidance.
Hugo Hofer - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 10,638
