简介
Is your Lite FX Rotating Big Ball of Lite Model 1929 disco ball making screechy noises instead of groovy beams? You probably need to grease up the gear to make that noise go away and bring back the jams. This guide will teach you how to get to the gear so you can grease it up and get back to partying!
你所需要的
Turn the device over so that the base is on top.
Use a pair of tweezers to crush the sides of the wirenuts.
Pull all of the wires out of the wirenuts.
Unscrew the two 10 mm philips head screws.
Unscrew the center 14 mm philips head screw.
Remove the plastic piece stabilizing the gear.
