跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何强制重启 iPhone 7 Plus
  1. 如何强制重启 iPhone 7 Plus, 如何强制重启 iPhone 7 Plus: 步骤 1 中的图像 1,2 如何强制重启 iPhone 7 Plus, 如何强制重启 iPhone 7 Plus: 步骤 1 中的图像 2,2
    • 要强制重启你的设备,同时按住“睡眠/唤醒”和”音量减“并维持至少十秒钟。
    • 这种强制重启程序与以前的型号不同,因为 iPhone 7系列没有能按下的物理 Home 按钮。
    My iPhone 7 Plus has a physical Home Button.
    Tony Olson - 回复
  2. 如何强制重启 iPhone 7 Plus: 步骤 2 中的图像 1,1
    • 继续按住这两个按钮并保持10秒,直到屏幕上出现 Apple 标志。
    What of if it didn't work after all the process
    Oma Livinus - 回复
    I boosted the battery and put it back it started to hot, the whole problem started after the battery drained off overnight
    Oma Livinus - 回复
    Please what do I need to do to have the phone working again?
    Oma Livinus - 回复
  3. 如何强制重启 iPhone 7 Plus: 步骤 3 中的图像 1,1
    • 当屏幕上出现 Apple 标志时松开按键,你的 iPhone 将会重新启动。
结论
你已经成功地重新启动了你的 iPhone 7 Plus。
87等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
Ou Hiroshizon正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Chris Mason
于01/31/16注册
4,881 声望
创作了2篇指南
团队
Fixteq Fixteq 的会员
Business
1 名成员
创作了16篇指南
15条评论
This threw me off when my wife's iPhone 7 froze. Plain and simple write up!
Morgan Cordry - 回复
Glad to have helped :)
Chris Mason -
not work my phone disable
mufi suma - 回复
and I can't restore it
mufi suma - 回复
Still doesn’t work
Saleka Chang - 回复
This operation is limited to the screen showing a black screen or crash. If your device does not power on or power up, connect your device to a power source and charge it for up to an hour. If the battery mark still does not appear on the screen, check if the charging device is in good condition.
If you still can not boot you can contact Apple Support, confirm the problem before the official repair or repair by yourself.
Ou Hiroshizon -
hi
i have iphone 7 and its restart self again and again after apple logo ?
Ali Zain - 回复
it still dose now work it turns on the apple logo and turns right back off help me pleaseee
kayla carter - 回复
excellent, i really thought my phone died for a sec…I was planning on buying another one til i saw this..! I havent ever really needed to do this! thanks!
alenakwong - 回复
if it not work, maybe your ios device system has some problem, you need to use professional third-party software named Fucosoft iOS System Recovery which can solve any ios system problem.
You can get it from here:https://www.fucosoft.com/ios-system-reco...
david_flynn - 回复
I replaced daughters screen and digitizer on iphone 7 plus as her was smashed beyond repair and followed step by step..to my amazement all was working again but when trying to snap screen back on the phone has completely gone of…CAN SOMEBODY PLEASE HELP
Jane Foster - 回复
After the iphone logo appear it still not turning own, can someone advice what i should do next
Synica D'souza - 回复
Not work and that not my mine email need remove everything
Jenny Hamilton - 回复
Wow this needs to be deleted as the 7 + still has a home button!!!! This why u can’t allow ppl who don’t know what they’re talking about on the internet at all!
krlink01 - 回复
iPhone 7s unlock karna chahta hu aapne i d vul gyahu na
Pradeep Sharma - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 140
过去 30 天: 694
总计 252,010
