跳转到主内容
How to force restart the OnePlus Nord
  1. How to force restart the OnePlus Nord, How to force restart the OnePlus Nord: 步骤 1 中的图像 1,1
    • Simultaneously push and hold the volume up and the power button.
    • Make sure you hit the UP part of the volume rocker. The down part will initiate a factory reset.
    • Release both buttons when you see the OnePlus logo come up.
    Finally - THAT worked!! Thanks. Other fixes from other sites tell you to press the “power off button”. Duh! Screen not responsive! Kudos for your research and answers.
    freerealm - 回复
    As you suggested i did it . Finally i got my mobile started.
    Epic Hemang - 回复
    I find charging port is too loose and does not connect with charging cord.. Battery charge runs out. What should I do?
    amicuscurious - 回复
    Most of the time its because there is dust in the charging port that causes that. Gently try to clean that and it should be good as new.
    Sparky -
终点
19等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
117,504 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
9条评论
what is this weird problem one plus nord suddenly get switch off while on call ..
kindly advice to get ride of this problem for forever .
Pushpa Rajput - 回复
My mobile has hanging & automatically switch off/on please solve problem
durga Viswanadh - 回复
It worked! Great help! Thank youuu
metaphysicalevil - 回复
Finally after trying for over 2 hours! Than you so much!
xkellileighx - 回复
mi telefono aparese que est corrupt i lo e reiniciado pero no enciende nomas cae eso
Leslie Alexa Garay - 回复
Ok now mine is stuck on the start and recovery menu but I can't select start bc my power button doesn't work
PRINCESS Jazz - 回复
Thanks a lot. The given tip has worked perfectly.
CBE K7 - 回复
Thank you so much for this.
Saket Agrawal - 回复
my 1 plus nord touch screen not working...i already have restart it many times with press power and long press volume ..now neither its swiching off nor working...please help me to atleast switching it off
Devansh Batra - 回复
添加评论
浏览统计数据:
过去 24 小时: 40
过去 7 天: 268
过去 30 天: 1,175
总计 110,863
