跳转到主内容
How to flash MNT Reform LPC firmware
你所需要的
  1. How to flash MNT Reform LPC firmware, Remove Bottom Plate Screws: 步骤 1 中的图像 1,1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
  2. How to flash MNT Reform LPC firmware, Remove Bottom Plate: 步骤 2 中的图像 1,1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
  3. How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: 步骤 3 中的图像 1,2 How to flash MNT Reform LPC firmware, Set LPCPROG switch to ON: 步骤 3 中的图像 2,2
    • Use a spudger or your fingernail to set the DIP switch LPCP to ON.
    • The LPCP switch is located on the motherboard, between the CPU module and trackball or trackpad.
  4. How to flash MNT Reform LPC firmware, Press LPCRESET: 步骤 4 中的图像 1,1
    • Use a spudger or your finger to press the LPCRST button next to the DIP switch from the previous step.
  5. How to flash MNT Reform LPC firmware, Plug in a USB cable: 步骤 5 中的图像 1,1
    • Connect a Micro-USB cable into the LPC USB port.
    • On newer revisions of the Reform, the Micro-USB port has been replaced with a USB type-C port.
  6. How to flash MNT Reform LPC firmware, Flash the LPC firmware: 步骤 6 中的图像 1,1
    • Plug the other end of the cable into another computer. The system controller's memory appears as a virtual flash drive on that computer.
    • Open a terminal and navigate to the reform2-lpc-fw folder you've downloaded from the Reform repository.
    • Check lsblk or dmesg -w to find out which drive the LPC shows up as, then edit flash.sh with the correct path to the virtual flash drive (e.g. /dev/sdx).
    • Double-check the path to make sure it is correct, as entering the wrong one could destroy data on your computer!
    • Execute flash.sh as root.
  7. How to flash MNT Reform LPC firmware, Unplug the USB cable: 步骤 7 中的图像 1,1
    • Disconnect the USB cable from the LPC USB port.
  8. How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: 步骤 8 中的图像 1,2 How to flash MNT Reform LPC firmware, Set LPCPROG switch to OFF: 步骤 8 中的图像 2,2
    • Use a spudger or your fingernail to set the DIP switch LPCP to OFF, which is the side labeled "1".
  9. How to flash MNT Reform LPC firmware, Press LPCRESET again: 步骤 9 中的图像 1,1
    • Use a spudger or your finger to press the LPCRST button again.
结论
To reassemble your device, follow steps 1 and 2 in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don't overtighten screws.
另外一个人完成了本指南。
Neelfyn
于05/13/14注册
972 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 34
总计 1,341
