跳转到主内容
How to fix the Oven Knob
你所需要的
  1. How to fix the Oven Knob, Oven Knob: 步骤 1 中的图像 1,1
    • Remove the plug of the oven from the socket for safety reasons.
  2. How to fix the Oven Knob: 步骤 2 中的图像 1,2 How to fix the Oven Knob: 步骤 2 中的图像 2,2
    • If the knob is loose, the first step is to completely remove the oven knob.
    • To remove it completely, hold it firmly and pull it straight off the shaft.
    • Make sure the knob is in the off position.
  3. How to fix the Oven Knob: 步骤 3 中的图像 1,3 How to fix the Oven Knob: 步骤 3 中的图像 2,3 How to fix the Oven Knob: 步骤 3 中的图像 3,3
    • If the screw is loosened beforehand, we first need to completely remove the screw from the shaft.
    • To remove the screw, use a Phillips #00 screwdriver to unscrew it from the shaft hole.
  4. How to fix the Oven Knob: 步骤 4 中的图像 1,1
    • Pull the shaft out and hold the shaft firmly. You will see two holes above and below this shaft.
  5. How to fix the Oven Knob: 步骤 5 中的图像 1,1
    • Now insert the screw in one of the holes.
  6. How to fix the Oven Knob: 步骤 6 中的图像 1,3 How to fix the Oven Knob: 步骤 6 中的图像 2,3 How to fix the Oven Knob: 步骤 6 中的图像 3,3
    • Tighten the screw with a screwdriver and make sure the screw is tightly attached.
    • Repeat the same process for the other hole.
  7. How to fix the Oven Knob: 步骤 7 中的图像 1,3 How to fix the Oven Knob: 步骤 7 中的图像 2,3 How to fix the Oven Knob: 步骤 7 中的图像 3,3
    • To fix the knob, slide the knob onto the shaft, aligning it with the D-shaped side of the shaft.
    • The front of the shaft is referred to as D-shaped because its shape resembles the letter D.
    • Now, with a little pressure, push on the shaft and affix the knob onto the shaft.
  8. How to fix the Oven Knob: 步骤 8 中的图像 1,1
    • Test the button by turning on the gas supply, and ensure that the knob operates smoothly and ignites the burner.
结论
This device is reassembled, follow these instructions in reverse order to disassemble.
3等其他人完成本指南。
Lovepreet Kaur
于09/04/23注册
211 声望
撰写一个指南
团队
York University, Team 2-10, O'Regan Fall 2023 York University, Team 2-10, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S2G10
1 名成员
创作了1篇指南
1指南评论
I’ve fixed this on mine several times now, but now the screw won’t tighten on one of them? Almost like whatever it gets screwed into isn’t there? Any idea on what is, not sure it’s worth opening up the back to see if something fell off.
AMKSNAPS - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 55
总计 900
