跳转到主内容
How to fix stick drift on the Oculus Quest 2
  1. How to fix stick drift on the Oculus Quest 2, Buy some isopropyl alcohol: 步骤 1 中的图像 1,1
    • Buy isopropyl alcohol, the higher the percentage the better it will work (this liquid will not damage electronics and is made to clean them).
    • Pour the alcohol on the joy stick (I would pour quite a bit on to make sure you can get all that dust) making sure it goes under and into the device, now move around the joy stick and work the alcohol into the underneath of the joystick (this removes the dust that causes stick drift).
    • Now leave the controller for about and hour to make sure all the alcohol evaporates to prevent damage. (You can leave it in a warm environment or use a hair dryer to heat up around the joy stick to be 100% certain. You won't have to heat it up very hot as this liquid evaporates very quickly).
    • Now enjoy no stick drift however this process will have to be repeated once dust forms again under the joy stick.
结论
2等其他人完成本指南。
kai jones
于07/27/23注册
187 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 98
总计 1,541
