跳转到主内容
加入维修社区 - 创建账户
How to fix scroll-wheel issues with Roccat Kone mice
你所需要的
  1. How to fix scroll-wheel issues with Roccat Kone mice, Disconnect the Mouse/Cover Sensor: 步骤 1 中的图像 1,1
    • Unplug the mouse.
    • Cover the optical sensor with tape.
  2. How to fix scroll-wheel issues with Roccat Kone mice, Loosen the Covers/Remove Screws: 步骤 2 中的图像 1,2 How to fix scroll-wheel issues with Roccat Kone mice, Loosen the Covers/Remove Screws: 步骤 2 中的图像 2,2
    • With a heat gun/hair dryer, warm up the covers. This will loosen up the glue that keeps the glider feet attached to the mouse.
    • Once hot, gently try to lift the gliders and work the edges.
    • To reapply, heat the gliders to make the the glue soft, then firmly hold it in place until it cools and holds its grip.
    • Once the gliders are removed, the screws are easily visible
    • Don't touch or dirty the adhesive side of the gliders, or else they won't stick back.
  3. How to fix scroll-wheel issues with Roccat Kone mice, Separate the plastic shell: 步骤 3 中的图像 1,2 How to fix scroll-wheel issues with Roccat Kone mice, Separate the plastic shell: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Be gentle when performing this step. Most Kone models have wires connecting the halves of the shell that may be damaged if you yank on them.
    • Turn the mouse back over and slowly lift off the top cover.
    • You may proceed without disconnecting the two halves if you wish. Ensure both halves are well supported so that the cable is not strained.
    • Use tweezers to disconnect the wires. If your model uses a ribbon cable, you will need to disengage the locking tab on the connector before pulling the cable out.
  4. How to fix scroll-wheel issues with Roccat Kone mice, Where to place the grease and testing the mouse: 步骤 4 中的图像 1,1
    • Spray electrical contact cleaner directly in the space indicated in the picture for several seconds, moving the scroll wheel back and forth as you spray.
    • Once the cleaner spray has evaporated, you may try connecting the mouse to your computer for testing before reassembly. You may encounter odd behavior if you leave the PCB in the shell disconnected while doing this.
    • If several repetitions of this step are not effective, the rotary encoder may be permanently damaged. Consider replacing it or the entire mouse.
结论
36等其他人完成本指南。
Isip V Nicola
于06/14/12注册
569 声望
撰写一个指南
24指南评论
####WARNING####
You better stick with the hair dryer when warming up the glue of the glidez.
I just performed this guide and it totally worked out. But I used a heat gun to warm up the mouse glidez. Due to the heat, the plastic that shapes the left mouse button, deformed a bit. The mouse is actually working normal, but you need a significant higher force to push the LMB now.
So be careful about the temperatures when warming the glidez.
Beside this fault of mine, the guide is perfect. Mouse wheel glitch is completely gone.
thx.
mmda81
Michael Ungers - 回复 分享
Thanks for the suggestion, already corrected. :)
Isip V Nicola - 回复 分享
Worked perfect with hair dryer and WD-40 in 15 minutes!
rinaf - 回复 分享
Excellent concise guide. Thank You!!!
brenogrady - 回复 分享
Thanks so much, it worked perfectly on a Roccat Savu. The side buttons were not working anymore after a mouse drop.
Just be patient with the glides & the hair drier.
John Doe - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 67
过去 30 天: 329
总计 81,084
