跳转到主内容
How to fix huion pen 420 Dropped-drawing while hovering
你所需要的
  1. How to fix huion pen 420 Dropped-drawing while hovering, disassemble: 步骤 1 中的图像 1,3 How to fix huion pen 420 Dropped-drawing while hovering, disassemble: 步骤 1 中的图像 2,3 How to fix huion pen 420 Dropped-drawing while hovering, disassemble: 步骤 1 中的图像 3,3
    • Remove the buttons first. (use a flat screw driver or something similar) (pic 1)
    • Push the silver tab & black tab down and push upwards to remove the mainboard
    • twist the white cylinder to adjust the height offset of the nub
    • if you want to fully dissasemble desolder the two copper leads and fully unscrew the while cylinder
  2. How to fix huion pen 420 Dropped-drawing while hovering: 步骤 2 中的图像 1,3 How to fix huion pen 420 Dropped-drawing while hovering: 步骤 2 中的图像 2,3 How to fix huion pen 420 Dropped-drawing while hovering: 步骤 2 中的图像 3,3
    • Use a soldering iron to remove the wire (remember which one goes where.) (pic 1)
    • Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2)
    • Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic (pic 3)
  3. How to fix huion pen 420 Dropped-drawing while hovering, Reassemble: 步骤 3 中的图像 1,2 How to fix huion pen 420 Dropped-drawing while hovering, Reassemble: 步骤 3 中的图像 2,2
    • Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity).
    • Remember to pull the metal up or else the pen won't have power. (pic 2)
结论
7等其他人完成本指南。
thlong123
于03/18/18注册
285 声望
撰写一个指南
17条评论
Man can I ask you something on google hangouts ? I couldn’t understand some points.
Peace Maker - 回复
I don't have hangout. Just ask here, I'll try to answer asap
thlong123 -
Why we need soldering iron?
Peace Maker -
To use in step 2
thlong123 -
I suspect this happened to mine but i dont have a soldering iron
Pixeled Forlife - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 62
总计 17,692
