跳转到主内容
How to fix an iPhone 4S that won't turn on or charge
你所需要的
  1. How to fix an iPhone 4S that won't turn on or charge, Do a forced restart: 步骤 1 中的图像 1,2 How to fix an iPhone 4S that won't turn on or charge, Do a forced restart: 步骤 1 中的图像 2,2
    • Press and hold the Power and Home buttons for 10 seconds.
    • Wait for about 10 seconds. If you don't see the Apple logo, continue to the next step.
  2. How to fix an iPhone 4S that won't turn on or charge, Charge the iPhone: 步骤 2 中的图像 1,1
    • Try charging the phone for at least 20 minutes.
    • You may also want to try using a different charger if you have one.
    • If this doesn't work, continue to the next step
  3. How to fix an iPhone 4S that won't turn on or charge, See if iTunes recognizes the iPhone: 步骤 3 中的图像 1,2 How to fix an iPhone 4S that won't turn on or charge, See if iTunes recognizes the iPhone: 步骤 3 中的图像 2,2
    • Try connecting the iPhone to a Windows or Mac computer and launch iTunes (If you don't have iTunes, you can download it at http://itunes.com/download) If you don't see an iPhone icon in the toolbar at the top left, continue to step 5
    • On macOS Catalina 10.15 or newer, go to the next step
  4. How to fix an iPhone 4S that won't turn on or charge, Hold home button while plugging in the charger: 步骤 4 中的图像 1,2 How to fix an iPhone 4S that won't turn on or charge, Hold home button while plugging in the charger: 步骤 4 中的图像 2,2
    • Allow the iPhone to charge for a while
    • Then hold down on the home button while plugging in the 30-Pin connector.
  5. How to fix an iPhone 4S that won't turn on or charge, Restore the iPhone: 步骤 5 中的图像 1,2 How to fix an iPhone 4S that won't turn on or charge, Restore the iPhone: 步骤 5 中的图像 2,2
    • If the previous step worked but you still can't see anything on the iPhone's screen, you may want to restore the iPhone.
    • THIS WILL ERASE ALL THE DATA ON THE iPHONE!
    • Connect the iPhone to a Windows or Mac computer and open iTunes, click the iPhone icon in the toolbar at the top left.
    • Click the "Restore iPhone" button at the top right to restore the iPhone.
  6. How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: 步骤 6 中的图像 1,3 How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: 步骤 6 中的图像 2,3 How to fix an iPhone 4S that won't turn on or charge, Instructions for macOS 10.15 and newer: 步骤 6 中的图像 3,3
    • Hold the control key while clicking on the Finder icon and select "New Finder Window"
    • In the Sidebar, look for the iPhone under "Locations", if you see the iPhone, select it.
    • You may be prompted to trust the iPhone to the computer.
    • If you don't see the iPhone then go to the next step.
结论
If you fixed it then CONGRATS! If you didn't fix it then, You may want to consider replacing the screen on the iPhone.
9等其他人完成本指南。
Elijah
于12/16/18注册
1,070 声望
创作了2篇指南
一条评论
So if I replace the screen, it will fix a stuck power button?
Edvard Ulven Refsdal - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 72
过去 30 天: 377
总计 12,459
