跳转到主内容
How to fix a printer that won't print
你所需要的
    • Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
    • A screwdriver.
    • A computer.
    • Printer ink.
    • This guide (obviously)
    • When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
    • Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
    • Remove the panel n
结论
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
2等其他人完成本指南。
Lappy4861
于03/11/24注册
183 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 40
总计 472
