跳转到主内容
How to fix a clogged garbage disposal
你所需要的
  1. How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: 步骤 1 中的图像 1,2 How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: 步骤 1 中的图像 2,2
    • Press the red reset button either on the front or on the bottom of your garbage disposal.
  2. How to fix a clogged garbage disposal: 步骤 2 中的图像 1,2 How to fix a clogged garbage disposal: 步骤 2 中的图像 2,2
    • Go to your breaker box and look for the breaker for your dishwasher. It may be attached to another appliance. Switch it off.
    • Do not continue without disconnecting the power.
  3. How to fix a clogged garbage disposal: 步骤 3 中的图像 1,2 How to fix a clogged garbage disposal: 步骤 3 中的图像 2,2
    • Unplug the garbage disposal from the outlet underneath the sink.
  4. How to fix a clogged garbage disposal: 步骤 4 中的图像 1,2 How to fix a clogged garbage disposal: 步骤 4 中的图像 2,2
    • Disconnect the garbage disposal pipe from the sewer pipe.
    • There may be excess water in this part of the pipe so place the bucket underneath.
  5. How to fix a clogged garbage disposal: 步骤 5 中的图像 1,2 How to fix a clogged garbage disposal: 步骤 5 中的图像 2,2
    • Using two screwdrivers, place them in the hooks on the top of the garbage disposal and push against them clockwise.
  6. How to fix a clogged garbage disposal: 步骤 6 中的图像 1,2 How to fix a clogged garbage disposal: 步骤 6 中的图像 2,2
    • Carefully bring down the garbage disposal from where it was connected to the sink.
  7. How to fix a clogged garbage disposal: 步骤 7 中的图像 1,1
    • Remove the splashguard at the top of the garbage disposal that you normally see from the top of your sink.
  8. How to fix a clogged garbage disposal: 步骤 8 中的图像 1,1
    • Using a screwdriver dislodge and remove any items clogging the disposal. This will give you an opportunity to manually move the blades around.
    • Never use your hand to move the blades.
结论
4等其他人完成本指南。
Katie Daffer
于02/23/16注册
257 声望
撰写一个指南
团队
Texas Tech, Team 26-1, Rauch Spring 2016 Texas Tech, Team 26-1, Rauch Spring 2016 的会员
TTU-RAUCH-S16S26G1
3 名成员
创作了1篇指南
2条评论
Would suggest also if you have a garbage disposal that has the hex wrench insert on the bottom you can use that to also spin the impeller to unjam the unit. Otherwise good to go
turbid - 回复
Yes most disposal units come with an Alan key so you can rotate the blades from the bottom of the unit. Rotate in each direction to un jam any thing check the red reset button. Then try it again most jams occur when not enough water is used to flush away the grinds.
Keith - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 38
总计 2,841
