跳转到主内容
How to fix a blown heater element in a Toaster
你所需要的
视频概述
    • Insert wisdom here.
    • how to fix a toaster
结论
Not too difficult, you need patience though.
4等其他人完成本指南。
jon
于05/15/16注册
2,949 声望
创作了22篇指南
2条评论
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - 回复
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 35
过去 30 天: 119
总计 24,940
