跳转到主内容
How to fix a G432 Logitech headset loose microphone arm
你所需要的
  1. How to fix a G432 Logitech headset loose microphone arm, How to fix a G432 Logitech headset loose microphone arm: 步骤 1 中的图像 1,3 How to fix a G432 Logitech headset loose microphone arm, How to fix a G432 Logitech headset loose microphone arm: 步骤 1 中的图像 2,3 How to fix a G432 Logitech headset loose microphone arm, How to fix a G432 Logitech headset loose microphone arm: 步骤 1 中的图像 3,3
    • Remove the ear pads by gently lifting them from the headset. They are easy to take off, so no need to be rough.
  2. How to fix a G432 Logitech headset loose microphone arm: 步骤 2 中的图像 1,2 How to fix a G432 Logitech headset loose microphone arm: 步骤 2 中的图像 2,2
    • First, unscrew the three visible screws. Use a size #1 Phillips screwdriver to remove the 1.2 mm screws.
    • There are four screws, one in each corner, and you should only be able to see three for now. The fourth one is hidden and can be dealt with later.
  3. How to fix a G432 Logitech headset loose microphone arm: 步骤 3 中的图像 1,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 3 中的图像 2,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 3 中的图像 3,3
    • After finishing with the three visible screws, look for the fourth screw. This one should be hidden behind a black sticker near the microphone arm.
    • Remove the sticker, and it is recommended to use a small tool that can peel the sticker off from underneath.
    • After removing the sticker, you can Remove the fourth and final screw, which is similar to the other three screws. Then open the headset cautiously, as the wires inside are short and sensitive.
  4. How to fix a G432 Logitech headset loose microphone arm: 步骤 4 中的图像 1,2 How to fix a G432 Logitech headset loose microphone arm: 步骤 4 中的图像 2,2
    • Take out the headphone part to continue to this step. While doing this, be meticulous to not have any rough movements that could potentially damage the wires.
    • There are four clips, one on every corner. Push these clips so they unclip and open the outer part of the headset.
  5. How to fix a G432 Logitech headset loose microphone arm: 步骤 5 中的图像 1,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 5 中的图像 2,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 5 中的图像 3,3
    • Similar to the previous step, opening the outer part of the headset will reveal even more wiring. Again, be careful with your hands to make sure the wires don't get harmed.
    • After pushing the clips, open the outside of the headset to see the microphone arm screw.
    • Screw the microphone arm screw and make it tighter so it won't be so loose. Use a size #3 Phillips screwdriver to take the screw out.
    • Be careful to not make the microphone arm too tight as that will completely restrict its movement.
  6. How to fix a G432 Logitech headset loose microphone arm: 步骤 6 中的图像 1,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 6 中的图像 2,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 6 中的图像 3,3
    • After fixing the microphone arm, put everything back together.
    • Simply line up the outer part of the headset and push it in so the clips can reconnect once again.
  7. How to fix a G432 Logitech headset loose microphone arm: 步骤 7 中的图像 1,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 7 中的图像 2,3 How to fix a G432 Logitech headset loose microphone arm: 步骤 7 中的图像 3,3
    • Simply screw back the four screws from earlier and put back the earpads, and it should be good to go!
终点
另外一个人完成了本指南。
Huu
于04/13/22注册
177 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-1, Harris Spring 2022 CSU Los Angeles, Team 1-1, Harris Spring 2022 的会员
CSULA-HARRIS-S22S1G1
1 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 47
总计 3,815
