跳转到主内容
How to fix a Detached Backpack Strap
你所需要的
  1. How to fix a Detached Backpack Strap, Prepare the area for the repair: 步骤 1 中的图像 1,3 How to fix a Detached Backpack Strap, Prepare the area for the repair: 步骤 1 中的图像 2,3 How to fix a Detached Backpack Strap, Prepare the area for the repair: 步骤 1 中的图像 3,3
    • Locate the detached strap and gather all the tools needed for the fix.
    • Note: In this example, the strap is not fully detached. However, if the backpack is worn extensively, the seam could break and the strap could come off completely.
  2. How to fix a Detached Backpack Strap, Clean the area: 步骤 2 中的图像 1,3 How to fix a Detached Backpack Strap, Clean the area: 步骤 2 中的图像 2,3 How to fix a Detached Backpack Strap, Clean the area: 步骤 2 中的图像 3,3
    • Remove the strap from the seam.
    • Use a pair of scissors and a seam ripper to cut the strap off and remove any loose threads.
    • Tip: You may need to remove both internal and external stitches. In this example, an internal binding (yellow arrow) also needed to be cut.
  3. How to fix a Detached Backpack Strap, Remove the strap: 步骤 3 中的图像 1,2 How to fix a Detached Backpack Strap, Remove the strap: 步骤 3 中的图像 2,2
    • Once the area has been cleaned, completely remove the strap from the seam in preparation for the next step.
  4. How to fix a Detached Backpack Strap, Fix the strap in place: 步骤 4 中的图像 1,3 How to fix a Detached Backpack Strap, Fix the strap in place: 步骤 4 中的图像 2,3 How to fix a Detached Backpack Strap, Fix the strap in place: 步骤 4 中的图像 3,3
    • Reintroduce the strap into the seam and secure it in place with sewing pins.
  5. How to fix a Detached Backpack Strap, Start sewing: 步骤 5 中的图像 1,3 How to fix a Detached Backpack Strap, Start sewing: 步骤 5 中的图像 2,3 How to fix a Detached Backpack Strap, Start sewing: 步骤 5 中的图像 3,3
    • Use a sewing machine to stitch the strap in place.
    • Make sure the needle is positioned on the side and not in the middle (red arrow).
    • After stitching, make sure that the seam is done back and forth and that it is fully fixed.
  6. How to fix a Detached Backpack Strap, Reinforce the stitch: 步骤 6 中的图像 1,3 How to fix a Detached Backpack Strap, Reinforce the stitch: 步骤 6 中的图像 2,3 How to fix a Detached Backpack Strap, Reinforce the stitch: 步骤 6 中的图像 3,3
    • Although a sewing machine is preferred, if the fabric is too thick, the stitching can be reinforced by hand.
    • Note: In this example, we use a combination of hand stitching and a sewing machine.
  7. How to fix a Detached Backpack Strap, Clean the area: 步骤 7 中的图像 1,3 How to fix a Detached Backpack Strap, Clean the area: 步骤 7 中的图像 2,3 How to fix a Detached Backpack Strap, Clean the area: 步骤 7 中的图像 3,3
    • Use a pair of scissors to clean the area and remove any loose threads.
  8. How to fix a Detached Backpack Strap, Finished and ready!: 步骤 8 中的图像 1,3 How to fix a Detached Backpack Strap, Finished and ready!: 步骤 8 中的图像 2,3 How to fix a Detached Backpack Strap, Finished and ready!: 步骤 8 中的图像 3,3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
结论
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
于07/19/23注册
10,230 声望
创作了66篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 20
总计 142
