跳转到主内容
How to fix a Bathroom Door that Will Not Latch
你所需要的
  1. How to fix a Bathroom Door that Will Not Latch, How to fix a Bathroom Door that Will Not Latch: 步骤 1 中的图像 1,1
    • Check for any screws that may have become loose over time in your door hinges.
  2. How to fix a Bathroom Door that Will Not Latch: 步骤 2 中的图像 1,1
    • If you found any loose screws on the door hinge, use your screwdriver to tighten them.
    • To make this easier, you can slightly lift your door while screwing the screws.
  3. How to fix a Bathroom Door that Will Not Latch: 步骤 3 中的图像 1,1
    • Examine the faceplate, checking for any loose screws like you did with your door hinges.
  4. How to fix a Bathroom Door that Will Not Latch: 步骤 4 中的图像 1,1
    • Use your screwdriver to tighten any loose screws found on the face plate.
  5. How to fix a Bathroom Door that Will Not Latch: 步骤 5 中的图像 1,1
    • This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
    • In the photo provided you can tell my plate has been shifted downwards.
  6. How to fix a Bathroom Door that Will Not Latch: 步骤 6 中的图像 1,2 How to fix a Bathroom Door that Will Not Latch: 步骤 6 中的图像 2,2
    • Use an electric power drill to remove the screws from your strike plate.
  7. How to fix a Bathroom Door that Will Not Latch: 步骤 7 中的图像 1,2 How to fix a Bathroom Door that Will Not Latch: 步骤 7 中的图像 2,2
    • Make a line on the wall where you will be moving your strike plate. Use something that you will be able to remove, such as a pencil.
  8. How to fix a Bathroom Door that Will Not Latch: 步骤 8 中的图像 1,2 How to fix a Bathroom Door that Will Not Latch: 步骤 8 中的图像 2,2
    • Using the wood chisel, chisel out the wood above the line to make space for the new placement of the strike plate.
    • An easy way to do this is to tap the end of the chisel with a hammer.
  9. How to fix a Bathroom Door that Will Not Latch: 步骤 9 中的图像 1,2 How to fix a Bathroom Door that Will Not Latch: 步骤 9 中的图像 2,2
    • Take as many toothpicks you will need to fill up the holes that were created for the previous screw holes, and dip them into the Elmer's glue.
  10. How to fix a Bathroom Door that Will Not Latch: 步骤 10 中的图像 1,3 How to fix a Bathroom Door that Will Not Latch: 步骤 10 中的图像 2,3 How to fix a Bathroom Door that Will Not Latch: 步骤 10 中的图像 3,3
    • Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
    • Let the toothpicks sit for about 10 minutes
  11. How to fix a Bathroom Door that Will Not Latch: 步骤 11 中的图像 1,1
    • Place the strike plate in its new position.
  12. How to fix a Bathroom Door that Will Not Latch: 步骤 12 中的图像 1,1
    • Using an electric drill, screw your strike plate into the wall.
结论
5等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 51
总计 4,114
