跳转到主内容
How to fix TC Electronic Level Pilot static noise
你所需要的
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: 步骤 1 中的图像 1,1
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: 步骤 2 中的图像 1,1
    • Spray the small opening there with some multi-purpose oil.
结论
11等其他人完成本指南。
6条评论
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - 回复
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - 回复
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - 回复
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - 回复
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - 回复
Yes oil is not a good idea. Thank you guys for the part. My one broke.
Alpha Dimension - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 24
总计 5,654
