跳转到主内容
How to fix Mobee Magic Mouse disconnection issues
你所需要的
视频介绍
终点
30等其他人完成本指南。
Peter Barnett
于09/04/16注册
732 声望
撰写一个指南
团队
Dragon Upstream Consulting Limited Dragon Upstream Consulting Limited 的会员
Business
1 名成员
创作了4篇指南
4条评论
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - 回复
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - 回复
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - 回复
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 39
过去 30 天: 184
总计 36,265
