跳转到主内容
How to fix Logitech Anywhere MX Phantom Double Click
你所需要的
  1. How to fix Logitech Anywhere MX Phantom Double Click, Front Screw Removal: 步骤 1 中的图像 1,1
    • The front screws are underneath the front gliders. The can be removed with a butterknive or Plastic Opening Tool. The gliders have three layers, be careful not to seperate them.
  2. How to fix Logitech Anywhere MX Phantom Double Click, Removing Back Screws: 步骤 2 中的图像 1,1
    • The back screws are underneath the stickers with the battery images. You can either remove them, like I did, or just poke a hole into them to get to the screws.
  3. How to fix Logitech Anywhere MX Phantom Double Click, Identification of the Problem: 步骤 3 中的图像 1,1
    • After the four screws are removed, the top and the bottom part can be easily taken apart. In the top part the grove that was made by the click-sensor should be cleary visible. This causes the phantom double clicks.
  4. How to fix Logitech Anywhere MX Phantom Double Click, Solution of the Problem: 步骤 4 中的图像 1,1
    • Put a piece of tape over the groove.
结论
63等其他人完成本指南。
43指南评论
Worked well for me, lets see how long it'll last.
Wynadorn - 回复
Worked for me too...saved a great little mouse!
jcrhino - 回复
Thank you for this hint! It worked perfectly
Wojciech Gradkowski - 回复
Thank you, it worked!
Jakab Ponoczky - 回复
Thank you for this guide! Got my mouse working and saved me some money :)
Kon-Kon Chao - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 46
过去 30 天: 272
总计 50,578
