跳转到主内容
How to fix Leaks in Shower Tiles by Caulking
你所需要的
  1. How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: 步骤 1 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: 步骤 1 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking, How to fix Leaks in Shower Tiles by Caulking: 步骤 1 中的图像 3,3
    • Using a putty knife, remove the old caulk from the surface.
    • While using the scraper, hold the sharp end away from you.
  2. How to fix Leaks in Shower Tiles by Caulking: 步骤 2 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 2 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 2 中的图像 3,3
    • Using a damp cloth, wipe the surface to remove the scraped caulking.
    • Using another cloth, wipe the surface with disinfectant.
  3. How to fix Leaks in Shower Tiles by Caulking: 步骤 3 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 3 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 3 中的图像 3,3
    • Place the caulking tube in the caulking gun.
    • Place the back of the tube into the gun.
    • Push the front of the tube inside.
    • Twist the hook at the end of the caulking gun inwards to hold the caulking tube in place.
  4. How to fix Leaks in Shower Tiles by Caulking: 步骤 4 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 4 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 4 中的图像 3,3
    • Cut the tip of the caulking tube at an angle.
    • Test the caulk on a paper towel before applying it on the surface.
    • Press the trigger on the caulking gun to release the caulk from the tube.
  5. How to fix Leaks in Shower Tiles by Caulking: 步骤 5 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 5 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 5 中的图像 3,3
    • Start caulking at the top of the surface and move down along the surface.
    • Place the tip of the caulking gun on the surface between two tiles and move it down at a steady pace.
    • Go back to the top and apply the caulking on the next tile, until all of the space between the tiles has caulking.
    • Hold the caulking gun with both hands to be steady.
  6. How to fix Leaks in Shower Tiles by Caulking: 步骤 6 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 6 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 6 中的图像 3,3
    • Using a damp finger, smoothen the caulking on the surface.
    • Keep a rag nearby to periodically wipe off any excess caulking.
    • Allow the caulking to dry for five minutes, before moving on to the next part.
  7. How to fix Leaks in Shower Tiles by Caulking: 步骤 7 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 7 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 7 中的图像 3,3
    • Now, apply the caulking in the horizontal direction.
    • Repeat the process in Step 5 and 6.
    • Allow the caulking to dry for 5 minutes before moving to the next part.
  8. How to fix Leaks in Shower Tiles by Caulking: 步骤 8 中的图像 1,2 How to fix Leaks in Shower Tiles by Caulking: 步骤 8 中的图像 2,2
    • Go over any areas that were missed or that don't have enough caulking.
    • Put a pea size amount of caulking in that area and smoothen it out with a damp finger.
  9. How to fix Leaks in Shower Tiles by Caulking: 步骤 9 中的图像 1,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 9 中的图像 2,3 How to fix Leaks in Shower Tiles by Caulking: 步骤 9 中的图像 3,3
    • Let the surface dry for 20 minutes.
    • After the caulking has dried, remove the excess using a putty knife.
    • To avoid scratches while removing the excess, lay the scrapper flat towards the surface.
  10. How to fix Leaks in Shower Tiles by Caulking: 步骤 10 中的图像 1,2 How to fix Leaks in Shower Tiles by Caulking: 步骤 10 中的图像 2,2
    • In case there is still any excess, scrub over the scraped area with a damp cloth.
    • If there is any caulking left over, cover the tip of the caulking tube with a paper towel and store for later use.
    • The caulking tube can be left in the caulking gun or taken out by performing step 4 backward.
结论
Clean the surface and completely let it dry before using it. It may take up to a full day to dry completely, so be prepared to not use the surface for a while!
另外一个人完成了本指南。
Suman Grewal
于04/26/20注册
208 声望
撰写一个指南
团队
UW Tacoma, Team S1-G36, Cardinal Spring 2020 UW Tacoma, Team S1-G36, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G36
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 29
总计 1,825
