跳转到主内容
How to extract a leaked battery from a pocket-torchlight
你所需要的
  1. How to extract a  leaked battery from a pocket-torchlight, battery: 步骤 1 中的图像 1,2 How to extract a  leaked battery from a pocket-torchlight, battery: 步骤 1 中的图像 2,2
    • To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
结论
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
2等其他人完成本指南。
ein Stein
于12/07/20注册
204 声望
撰写一个指南
7条评论
works like a charm! there is no better way. obviously, the leaked battery is being destroyed in the process.
ein Stein - 回复
works for aluminium € 30 “creed-light”
ein Stein - 回复
getting the battery out is much easier than publishing a guide here. wow they make it complicated!
ein Stein - 回复
don’t forget to scratch off any insulating rust caused by the electrolyte on the battery–contacts of the torchlight.
ein Stein - 回复
fragile plastic torches may not withstand the force required to drill, breaking the torch.
unless you have a strong magnet to pull the battery, it is unfortunate.
ein Stein - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 56
总计 922
