跳转到主内容
How to enable charging past 90%
  1. How to enable charging past 90%, Attach the Battery Pack to the iPhone: 步骤 1 中的图像 1,2 How to enable charging past 90%, Attach the Battery Pack to the iPhone: 步骤 1 中的图像 2,2
    • Attach the MagSafe Battery Pack to the MagSafe location on the back of the iPhone.
    • The Apple logo on the MagSafe Battery Pack lines up with the Apple logo on your phone. This can help in positioning.
    • The LED indicator may glow green or amber depending upon the Battery Pack's charge condition.
  2. How to enable charging past 90%, Indications of the Battery Pack: 步骤 2 中的图像 1,3 How to enable charging past 90%, Indications of the Battery Pack: 步骤 2 中的图像 2,3 How to enable charging past 90%, Indications of the Battery Pack: 步骤 2 中的图像 3,3
    • An onscreen toast will appear indicating the presence of the Battery Pack. The toast will indicate the following:
    • The charge level of the iPhone (icon and percentage).
    • The charge level of the Battery Pack (icon).
    • Indicate that the iPhone is accepting a charge.
    • Home screen widgets for Battery will indicate the charge level of the Battery Pack. The widget may also indicate if the Battery Pack is being charged (i.e. by cable, or by reverse charging).
  3. How to enable charging past 90%, Add Low Power Mode to Control Center: 步骤 3 中的图像 1,2 How to enable charging past 90%, Add Low Power Mode to Control Center: 步骤 3 中的图像 2,2
    • Ensure that the Low Power Mode option is available in Control Center.
    • Enter Settings, Control Center. If "Low Power Mode" is not listed under "Included Controls," scroll down to "More Controls" and click the green plus sign to add it.
    • Verify it is now available under "Included Controls," and exit Settings.
    • For more information on editing the Control Center, see the Apple KB article.
  4. How to enable charging past 90%, Enable 100% charging in the Low Power Mode control: 步骤 4 中的图像 1,2 How to enable charging past 90%, Enable 100% charging in the Low Power Mode control: 步骤 4 中的图像 2,2
    • Bring up the Control Center in iOS on your iPhone. (Method depends upon the model and iOS version. Generally, swipe down from the upper right corner.)
    • Locate the Low Power Mode button, and tap it.
    • Enable the "Charge past 90%" option now available with the MagSafe Battery Pack attached.
    • Tap the screen to dismiss the popup, then dismiss the Control Center.
    • For more information on Low Power Mode, see the Apple KB article.
结论
For more information on using the MagSafe Battery Pack, see the Apple KB article.
另外一个人完成了本指南。
David Spalding
于11/12/15注册
6,461 声望
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 87
总计 905
