跳转到主内容
How to empty and clean Rival 16131 Toaster crumb tray
你所需要的
  1. How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: 步骤 1 中的图像 1,2 How to empty and clean Rival 16131 Toaster crumb tray, How to empty and clean Rival 16131 Toaster crumb tray: 步骤 1 中的图像 2,2
    • To open the crumb tray, pinch the lever in the photo.
    • If the lever does not keep the the crumb tray closed, stretch the lever so that to make sure the two horizontal pieces are aligned.
  2. How to empty and clean Rival 16131 Toaster crumb tray: 步骤 2 中的图像 1,1
    • Now that the tray is exposed, it is possible to clean the face here.
    • Try to not let water get into the toaster as this may damage the heating coil.
    • If the tray can not be cleaned simply by opening it, keep going through the guide to fully remove it.
  3. How to empty and clean Rival 16131 Toaster crumb tray: 步骤 3 中的图像 1,3 How to empty and clean Rival 16131 Toaster crumb tray: 步骤 3 中的图像 2,3 How to empty and clean Rival 16131 Toaster crumb tray: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • To remove the tray, the metal hinges must be bent up.
    • While applying pressure to the bottom of the toaster, use pliers or tweezers to bend up the bracket. The pressure applied to the bottom of the toaster should be just enough to allow the bracket to swing up.
    • Remove the tray and clean.
结论
Grant Haug
于09/26/12注册
148 声望
创作了4篇指南
团队
Cal Poly, Team 2-8, Propen Fall 2012 Cal Poly, Team 2-8, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G8
5 名成员
创作了6篇指南
1指南评论
Thanks! This was helpful. :)
Tracy Emmanuel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 3,527
