跳转到主内容
How to easily fix a Xbox 360 drive that wont open.
你所需要的
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 步骤 1 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 步骤 1 中的图像 2,2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: 步骤 2 中的图像 1,1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
    Depending on who manufactured the drive, the hole might not be in the same place. On mine, there is no metal hole behind that white plastic hole. If you look in the photo for step 1, follow the edge of the white plastic just below the metal door of the tray. There are two white notches towards the left side. The one closer to the middle of the unit is often the one to push the tool into. But it took me many tries to get it right - very easy to miss. If the tool goes too far in you are too high - try angling slightly down, away from the door.
    Once you get it open, try blowing compressed air all around in there, and manually push and pull the tray a few times. In my case that was good enough to get it working again.
    Matt D - 回复
  3. How to easily fix a Xbox 360 drive that wont open.: 步骤 3 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: 步骤 4 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 4 中的图像 2,2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: 步骤 5 中的图像 1,1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: 步骤 6 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 6 中的图像 2,2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
结论
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
15等其他人完成本指南。
Matt Weatherly
于09/16/12注册
1,305 声望
创作了2篇指南
8条评论
the picture of the exbox is not mine
dongwillows - 回复
the picture you show is not my console
dongwillows - 回复
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - 回复
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Gustavo Montes - 回复
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
How do you get from Step 2 to Step 3? Take apart the console right?
Patrick Hoffer - 回复
The disc drive on mine didn't have that hole that you used to turn the gear, so I had to improvise. I was able to get it cleaned though
Kade Barker - 回复
Yes it's ok, there's a wide hole with a wheel and you have to turn the wheel to the right until the disc drive goes done and you can pull it out.
leonard ufer -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 121
总计 11,176
