跳转到主内容
配件
没有特定配件。
  1. How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 步骤 1 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open., How to easily fix a Xbox 360 drive that wont open.: 步骤 1 中的图像 2,2
    • First we need to take off the face plate.
  2. How to easily fix a Xbox 360 drive that wont open.: 步骤 2 中的图像 1,1
    • Use a paper clip or a long pick tool to manually open DVD Drive.
  3. How to easily fix a Xbox 360 drive that wont open.: 步骤 3 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 3 中的图像 2,2
    • Use tweezers to take a rubber belt of 2 pulleys in between the hole in the DVD Tray.
  4. How to easily fix a Xbox 360 drive that wont open.: 步骤 4 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 4 中的图像 2,2
    • Use a damp paper towel to thoroughly clean the rubber belt.
  5. How to easily fix a Xbox 360 drive that wont open.: 步骤 5 中的图像 1,1
    • Use the tweezers to put the rubber belt back on the 2 pulleys we took them off of.
    • I have found it is easier to start with the big pulley first then once around the big pulley get the belt around the small belt.
  6. How to easily fix a Xbox 360 drive that wont open.: 步骤 6 中的图像 1,2 How to easily fix a Xbox 360 drive that wont open.: 步骤 6 中的图像 2,2
    • Close the DVD Drive and put the face plate back on.
    • Plug the system in and test to see if the drive works.
结论
These steps have helped me fix 2 original Xbox systems and 3 Xbox 360 systems. I hope it helps yall. If you need any clarification on any of the steps please message me.
12等其他人完成本指南。
Matt Weatherly
于2012年09月16日注册
1,043 信誉积分
创作了2篇指南
6条评论
the picture of the exbox is not mine
dongwillows - 回复
the picture you show is not my console
dongwillows - 回复
My xbox 360 console looks like this but does not have a hole to manually open the tray.
Don - 回复
It had to use different tools to open and clean the rubber pulley with 70% Alcohol. Thank you for posting it i fixed my 2009 Black xbox 360 Console.
Dr. Mario - 回复
How did you open your Xbox? Because mine also doesn’t have that hole
Astr0 -
添加评论
浏览统计数据:
过去的24小时: 8
过去的7天: 49
过去的30天: 236
总计 6,853
