跳转到主内容
How to perform a Hard Reset on the Nintendo DS Lite
你所需要的
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: 步骤 1 中的图像 1,1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: 步骤 2 中的图像 1,2 How to perform a Hard Reset on the Nintendo DS Lite: 步骤 2 中的图像 2,2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 步骤 3 中的图像 1,2 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: 步骤 3 中的图像 2,2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 步骤 4 中的图像 1,3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 步骤 4 中的图像 2,3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: 步骤 4 中的图像 3,3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: 步骤 5 中的图像 1,1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 步骤 6 中的图像 1,3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 步骤 6 中的图像 2,3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: 步骤 6 中的图像 3,3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 步骤 7 中的图像 1,2 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: 步骤 7 中的图像 2,2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: 步骤 8 中的图像 1,1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
结论
3等其他人完成本指南。
Artem Ivat
于02/05/20注册
2,709 声望
创作了12篇指南
团队
Kid fixers Kid fixers 的会员
Community
156 名成员
创作了292篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 96
过去 30 天: 376
总计 9,339
