跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide will help you to remove the cover plates from your Canon digital camera.
配件
没有特定配件。
  1. Using a Tri-Wing screwdriver #0, remove the screws from the sides of the camera. There are two on each side, and two on the bottom plate. There are two on each side, and two on the bottom plate.
    • Using a Tri-Wing screwdriver #0, remove the screws from the sides of the camera.
    • There are two on each side, and two on the bottom plate.
  2. Gently grip and remove the side cover while holding the Mini-USB cover open. Gently grip and remove the side cover while holding the Mini-USB cover open.
    • Gently grip and remove the side cover while holding the Mini-USB cover open.
  3. Grip the camera from the sides and carefully remove the screen cover. Start at the bottom edge and slowly lift up the cover. Pay special attention to the area with the camera/video switch. While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off. While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off.
    • Grip the camera from the sides and carefully remove the screen cover. Start at the bottom edge and slowly lift up the cover. Pay special attention to the area with the camera/video switch.
    • While still gripping the sides, remove the front cover. Again, start at the bottom edge and slowly lift up the cover. Once you are done with the screen cover, remove the screw by the power switch that is anchoring the side plate and the sides will come off.
结论
3等其他人完成本指南。
Stanley
于2011年01月30日注册
372 信誉积分
创作了4篇指南
团队
Cal Poly, Team 4-33, Regan Winter 2011 Cal Poly, Team 4-33, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G33
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 2
过去的30天: 23
总计 5,016
