简介
Did you forget to clean Bob's front wheel as a part of your regular maintenance to the point that the wheel is completely stuck? Not to worry! Here is how to disassemble, clean, and reassemble Bobsweep's front wheel.
你所需要的
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
There is one screw holding the front wheel in place. It is found in front of bObsweep's main board.
Hold the wheel from underneath bObsweep while removing the screw.
Lift bObsweep up and the front wheel will be removed.
There are four washers between the front wheel and bObsweep. They usually sit on top of the wheel, but can sometimes get stuck on bObsweep. Make sure to check underneath your vacuum if any pieces are missing.
There will be one wide black washer that fits in the grooved section of the wheel.
The other three washers make up the bearing assembly on the innermost ring of the wheel.
Thorough cleaning of the wheel ensures better performance and can be performed as often as necessary.
