简介
The disassembly of this water kettle can be done by anyone with the help of this manual and the required tools. At one point, you might need and extra pair of hands, so make sure that someone is available when needed.
你所需要的
After this, locate the three, already visible screws and unscrew two of the three screws with a PH2 and the other one with a PH 1 screwdriver.
Next, you can detach the black plastic part with the switch after loosening the red wires from the plastic. With this, you can remove the plastic tube as well.
To reassemble the device, follow these instructions in reverse order.
由衷感谢以下译者:
100%
Corey Meyer正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
