跳转到主内容
How to diagnose Samsung Galaxy A40 Charging Problems
视频概述
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 步骤 1 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 步骤 1 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: 步骤 1 中的图像 3,3
    • These photos depict the +5V line from the charging port to the motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 步骤 2 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 步骤 2 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: 步骤 2 中的图像 3,3
    • Heat the device to soften the adhesive.
    • Tools you may find of use include a playing card, suction cup, plastic tools such as picks and a spudger and isopropyl alcohol (preferably not rubbing alcohol - contains oils and perfumes).
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 步骤 3 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 步骤 3 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: 步骤 3 中的图像 3,3
    • Remove the plastic cap from the fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 步骤 4 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 步骤 4 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: 步骤 4 中的图像 3,3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 步骤 5 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 步骤 5 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: 步骤 5 中的图像 3,3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: 步骤 6 中的图像 1,3 How to diagnose Samsung Galaxy A40 Charging Problems: 步骤 6 中的图像 2,3 How to diagnose Samsung Galaxy A40 Charging Problems: 步骤 6 中的图像 3,3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
结论
6等其他人完成本指南。
ZFix
于12/09/13注册
195,943 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
1指南评论
How to fix samsung A50s with termometer logo on screen when charging
Den Bagoese - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 38
过去 30 天: 156
总计 11,951
