跳转到主内容
How to create and install a Cisco EX90 console cable
你所需要的
  1. How to create and install a Cisco EX90 console cable, How to create and install a Cisco EX90 console cable: 步骤 1 中的图像 1,1
    • Gather the necessary tools
    • 1--Soldering Iron
    • 2--Solder
    • 3--DB9 Enclosure. This one is being used here.
    • 4--RS232 to TTL/CMOS converter. alldav.com sells the one used here. Cisco does not recommend or endorse Alldav specifically.
    • 5--Cable w/RJ45 connector on one end Any type of cable with an 8P8C (RJ45) connector could used as long as pins 1,2,7 & 8 are connected. A standard RJ45 cable is being used here.
    • You will also need wire strippers and possibly a screwdriver (depending on which DB9 enclosure you are using).
  2. How to create and install a Cisco EX90 console cable: 步骤 2 中的图像 1,1
    • Prep the cable. Strip the sheathing from the wires that correspond to pins 1,2,7 & 8.
  3. How to create and install a Cisco EX90 console cable: 步骤 3 中的图像 1,1
    • Connect the RS232 to TTL/CMOS converter. Connect the RS232 to TTL/CMOS converter to the cable and solder the connections. Note: The colors used in the wiring diagram don't correspond to the color of the actual wires.
  4. How to create and install a Cisco EX90 console cable: 步骤 4 中的图像 1,1
    • Install the Enclosure The EX90 console is now complete. The subsequent steps will cover making a console connection.
  5. How to create and install a Cisco EX90 console cable: 步骤 5 中的图像 1,1
    • Make a Console Connection. Locate the Console Port. The EX90 console port is an 8P8C (RJ45) connection and is located on the bottom left corner of the unit.
  6. How to create and install a Cisco EX90 console cable: 步骤 6 中的图像 1,1
    • Connect to the Console Port. Plug the 8P8C (RJ45) end into the console port. You'll have to lean the unit forward to plug the cable in. It might be a little awkward to do alone. If someone else is available, ask for their assistance. As a last resort, lay the unit down. Ensure you have something soft (like a towel) to lay the unit on.
  7. How to create and install a Cisco EX90 console cable: 步骤 7 中的图像 1,1
    • Connect the DB9 to a USB serial adapter and connect to a laptop/PC.
  8. How to create and install a Cisco EX90 console cable: 步骤 8 中的图像 1,1
    • Configure a Terminal Emulator Session Configure your terminal emulator with the following parameters:
    • Baud=38400
    • Data bits=8
    • Parity=none
    • Stop bits=1
    • Flow Control=none
    • The example uses HyperTerminal for Windows; configuring your terminal emulator may vary slightly.
    • You should now be at a login prompt when you connect with the terminal emulator.
终点
2等其他人完成本指南。
eric
于05/17/12注册
241 声望
撰写一个指南
1指南评论
Thanks for this Amazing Blog. It is very informative and helpful for me.
<a href="http://pdfdumps.us/exam/220-801.html">Pass4sure 220-801 dumps</a>
ademarr - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 24
过去 30 天: 60
总计 8,116
