跳转到主内容
How to create a Tails Live USB
你所需要的
  1. How to create a Tails Live USB, Download Tails OS: 步骤 1 中的图像 1,2 How to create a Tails Live USB, Download Tails OS: 步骤 1 中的图像 2,2
  2. How to create a Tails Live USB, Download and install BalenaEtcher: 步骤 2 中的图像 1,1
    • Insert the USB flash drive into an available USB port on your computer and launch Etcher.
    • In Etcher, click "Flash from file" and select the Tails ISO image you downloaded earlier.
    • Select the USB flash drive as the target device.
    • Double-check to ensure you have selected the correct drive, as the process will erase all data on the selected drive.
    • Click "Flash!" to start the process. Etcher will copy the Tails OS to the USB drive.
    • Once the flashing process is complete, safely eject the USB drive from your computer.
    • Etcher should do this automatically, however it is still good practice to check that the drive was ejected properly.
    • Insert the Tails live USB into the computer you want to use.
    • Restart the computer and enter the boot menu by pressing the appropriate key during startup (usually F2, F12, or Delete).
    • Select the USB drive as the boot device from the boot menu.
    • Tails will start, and you'll be presented with the Tails Greeter screen.
    • Follow the on-screen instructions to configure language, keyboard, and other settings.
    • Once completed you will be able to use your computer in a secure and private live environment. Your online activities are routed through the Tor network for anonymity.
结论
Creating a Tails live USB using this iFixit guide provides you with a secure and private way to use Tails OS on any computer without leaving traces. Remember to always use Tails responsibly and respect the privacy and security it offers.
7等其他人完成本指南。
Jacob Mehnert
于10/18/21注册
44,314 声望
创作了51篇指南
团队
iFanatics iFanatics 的会员
Community
63 名成员
创作了219篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 50
过去 7 天: 260
过去 30 天: 1,286
总计 19,225
