简介
If your Chromebook's operating system every becomes corrupted or damaged, you can recover it using Googles Recovery Utility application. This process has the tool completely remove the currently installed OS, and reinstalls it onto the device.
While Chrome OS is known for being a somewhat stable operating system there are moments where you would want to have a recovery drive handy. For example, you would want to use a recovery USB in one of the following scenarios...
- You see this error message: "Chrome OS is missing or damaged"
- Other troubleshooting steps have no effect on the immediate issue.
工具
配件
没有特定配件。
In order to make your recovery device, you will need the following items.
1 x USB Drive or SD Card (8 GB is the minimum)
1 x computer running the Google Chrome Browser, or Chrome OS.
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
另外一个人完成了本指南。
