简介
You will be using Carbon Copy Cloner for this guide. Cloning a Hard Drive or a Solid State Drive is about as easy as it gets with CCC. Sadly, CCC is only available to macOS users and is not compatible with Linux or Windows. Sometime soon I will create a guide for Windows and Linux users.
你所需要的
Download Carbon Copy Cloner from the Bombich Software Website.
Install it onto your macOS based computer. You will need administrator privileges later, as well as to move CCC into the Applications folder on your computer.
Once you are at the main screen of Carbon Copy Cloner, insert your SATA based SSD/SSHD/HDD into your enclosure and plug it into your Mac.
Under Source Disk, click your current HD/SSD. For example, my current drive is named "Macintosh SSD".
Next, select your Target Disk. My target disk is named "Ubuntu". Your disk can have any type of name ex. "Pie".
Lastly, click Clone.
Enter your administrator Username
Enter your administrator Password
Then finally, click OK
After you finish, install your new Hard Drive/Solid State Drive and test if it works. If it does not, try cloning again. If it still does not work after that, leave a comment and I will try my best to support you.
25等其他人完成本指南。
8条评论
What if you have several volumes on each disk ? Does it scan the entire structure and boot options ?
CCC clones per volume, not per disk. So you have to clone each volume on their own, how many are bootable?
Jelan -
