跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide can teach you how to repair/remove a paper jam for the Epson Stylus Photo 820. No tools are necessary for this operation, and no working knowledge of the printer is needed.
  1. If a paper jam is detected, the middle button will display a red light. Press the red button. This will cause the printer to try to automatically correct the issue.
    • If a paper jam is detected, the middle button will display a red light.
    • Press the red button. This will cause the printer to try to automatically correct the issue.
    • If this works, proceed to step 4. Otherwise, proceed to step 2.
  2. The first step in repair is to attempt to remove the paper jam by pulling it out through the top. Pull the paper slowly, and as straight as possible.
    • The first step in repair is to attempt to remove the paper jam by pulling it out through the top.
    • Pull the paper slowly, and as straight as possible.
    • If this does not work, proceed to step 3.
  3. Assuming the paper will not come out of the top, assess the paper jam. If the print cartridge is in the way, gently push it to the side.
    • Assuming the paper will not come out of the top, assess the paper jam.
    • If the print cartridge is in the way, gently push it to the side.
    • Try to get the full edge of the paper above the metal grating.
    • Gently pull the paper out the of the open hatch.
  4. If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light. If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • If the paper jam was corrected during step 1, the red light should have turned off, leaving only a green light.
    • If steps 2 or 3 corrected the problem, you will need to press the red button again.
    • This may cause another sheet of paper to be pulled through. Do not be alarmed.
    • This should cause the red light to go out.
终点
另外一个人完成了本指南。
dante gagliardi
于2011年04月13日注册
45 信誉积分
创作了2篇指南
团队
Cal Poly, Team 20-68, Walters Spring 2011 Cal Poly, Team 20-68, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G68
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 3,002
