跳转到主内容
How to clear Lexmark Intuition S505 paper jam
  1. How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: 步骤 1 中的图像 1,2 How to clear Lexmark Intuition S505 paper jam, How to clear Lexmark Intuition S505 paper jam: 步骤 1 中的图像 2,2
    • Lift the scanning unit.
  2. How to clear Lexmark Intuition S505 paper jam: 步骤 2 中的图像 1,2 How to clear Lexmark Intuition S505 paper jam: 步骤 2 中的图像 2,2
    • Check the duplex unit, located at the rear of the printer, for any paper obstruction. Pinch the top button to remove the unit.
  3. How to clear Lexmark Intuition S505 paper jam: 步骤 3 中的图像 1,1
    • If there is any paper stuck inside, remove it. If not, snap the unit back onto the printer.
  4. How to clear Lexmark Intuition S505 paper jam: 步骤 4 中的图像 1,1
    • Check the front slot, which is located underneath the LED display. If there is any paper, remove it.
结论
Once the paper obstruction is removed, your printer should print smoothly without any problems.
2等其他人完成本指南。
Omar
于01/23/13注册
111 声望
创作了2篇指南
团队
Cal Poly, Team 18-38, Regan Winter 2013 Cal Poly, Team 18-38, Regan Winter 2013 的会员
CPSU-REGAN-W13S18G38
4 名成员
创作了8篇指南
一条评论
Mine still says paper jam but there's no paper stuck in it all. Can you suggest other probs and solutions?
Debra Collis (Debbie) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,639
