跳转到主内容
How to clean/replace buttons on the Skytex SP728
你所需要的
  1. How to clean/replace buttons on the Skytex SP728, Case: 步骤 1 中的图像 1,1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: 步骤 2 中的图像 1,1
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: 步骤 3 中的图像 1,1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: 步骤 4 中的图像 1,1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: 步骤 5 中的图像 1,1
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: 步骤 6 中的图像 1,1
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
结论
另外一个人完成了本指南。
Chris Nelson
于01/21/15注册
213 声望
创作了2篇指南
团队
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 的会员
USFT-BROWN-W15S5G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 127
