跳转到主内容
How to clean your Panasonic SA-HT810V VCR heads
你所需要的
  1. How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 步骤 1 中的图像 1,3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 步骤 1 中的图像 2,3 How to clean your Panasonic SA-HT810V VCR heads, How to clean your Panasonic SA-HT810V VCR heads: 步骤 1 中的图像 3,3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. How to clean your Panasonic SA-HT810V VCR heads: 步骤 2 中的图像 1,2 How to clean your Panasonic SA-HT810V VCR heads: 步骤 2 中的图像 2,2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the 12 screws highlighted by the red circles in image one.
  3. How to clean your Panasonic SA-HT810V VCR heads: 步骤 3 中的图像 1,1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. How to clean your Panasonic SA-HT810V VCR heads: 步骤 4 中的图像 1,3 How to clean your Panasonic SA-HT810V VCR heads: 步骤 4 中的图像 2,3 How to clean your Panasonic SA-HT810V VCR heads: 步骤 4 中的图像 3,3
    • Before cleaning the VCR heads, be sure that the front of the device is facing you with the top cover removed.
    • Locate the two VCR heads highlighted in by the blue boxes in image one.
    • GENTLY clean heads with a microfiber rag and a cleaning solution of your choice.
结论
2等其他人完成本指南。
Nathan Cheadle
于04/15/10注册
161 声望
创作了7篇指南
团队
Cal Poly, Team 16-5, Maness Spring 2010 Cal Poly, Team 16-5, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G5
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 2,599
