跳转到主内容
加入维修社区 - 创建账户
How to clean the Sega Genesis game port
你所需要的
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: 步骤 1 中的图像 1,1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: 步骤 2 中的图像 1,1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: 步骤 3 中的图像 1,1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: 步骤 4 中的图像 1,1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
终点
12等其他人完成本指南。
团队
Cal Poly, Team 3-29, Regan Fall 2010 Cal Poly, Team 3-29, Regan Fall 2010 的会员
CPSU-REGAN-F10S3G29
4 名成员
创作了14篇指南
5指南评论
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - 回复 分享
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - 回复 分享
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - 回复 分享
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - 回复 分享
I tried alcohol and toothbrush, q-tips, and looked over the board for circuit problems. I was still getting a black screen for every game i tried. But this worked perfectly. I'm shocked. My contacts were already shiny clean but they needed light sandpaper apparently.
colinplank - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 45
过去 30 天: 127
总计 39,053
