跳转到主内容
How to clean the Samsung SGH-E317 keypad
你所需要的
  1. How to clean the Samsung SGH-E317 keypad, Battery: 步骤 1 中的图像 1,1
    • Remove the back panel by pressing up on switch, located at the top on the back of the phone.
    • You may want to use a plastic opening tool to help pry the back panel off.
  2. How to clean the Samsung SGH-E317 keypad, Motherboard: 步骤 2 中的图像 1,1
    • Unscrew the four 4.5mm screws located on the back plate.
  3. How to clean the Samsung SGH-E317 keypad: 步骤 3 中的图像 1,1
    • Remove the rubber screw cover using your fingernail.
  4. How to clean the Samsung SGH-E317 keypad: 步骤 4 中的图像 1,1
    • Unscrew the 4.5mm screw located underneath the rubber cover.
  5. How to clean the Samsung SGH-E317 keypad: 步骤 5 中的图像 1,1
    • Wedge the end of a plastic opening tool into the crack between the back panel and the phone.
    • The panel should come off without much effort.
  6. How to clean the Samsung SGH-E317 keypad: 步骤 6 中的图像 1,1
    • With the back panel removed, the motherboard should be fully exposed.
  7. How to clean the Samsung SGH-E317 keypad: 步骤 7 中的图像 1,2 How to clean the Samsung SGH-E317 keypad: 步骤 7 中的图像 2,2
    • Remove the camera and volume buttons and place them in a safe spot until reassembly.
  8. How to clean the Samsung SGH-E317 keypad: 步骤 8 中的图像 1,2 How to clean the Samsung SGH-E317 keypad: 步骤 8 中的图像 2,2
    • Using a plastic opening tool, unplug the ribbon cable connecting the front LCDs to the motherboard.
  9. How to clean the Samsung SGH-E317 keypad: 步骤 9 中的图像 1,2 How to clean the Samsung SGH-E317 keypad: 步骤 9 中的图像 2,2
    • Detach the motherboard by grabbing the edges of it and lifting it straight out of the phone.
  10. How to clean the Samsung SGH-E317 keypad, How to clean the Samsung SGH-E317 keypad: 步骤 10 中的图像 1,1
    • After removing motherboard, the phone will look like this.
  11. How to clean the Samsung SGH-E317 keypad: 步骤 11 中的图像 1,1
    • Grab the corner of the rubber key pad and lift out slowly.
  12. How to clean the Samsung SGH-E317 keypad: 步骤 12 中的图像 1,2 How to clean the Samsung SGH-E317 keypad: 步骤 12 中的图像 2,2
    • By using a small standard screwdriver and a fine, thin, soft cloth you can clean in between the keypad to remove dirt and debris.
结论
另外一个人完成了本指南。
Joe Cavaletto
于01/30/11注册
101 声望
撰写一个指南
团队
Cal Poly, Team 11-23, Maness Winter 2011 Cal Poly, Team 11-23, Maness Winter 2011 的会员
CPSU-MANESS-W11S11G23
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 13
总计 956
