跳转到主内容
How to clean the SAECO Incanto SBS Spout
你所需要的
  1. How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: 步骤 1 中的图像 1,3 How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: 步骤 1 中的图像 2,3 How to clean the SAECO Incanto SBS Spout, How to clean the SAECO Incanto SBS Spout: 步骤 1 中的图像 3,3
    • Remove the spout by pressing the button on top and sliding it towards you.
    • Unscrew the two PH#1 screws on the back of the spout.
    • The spout halves should now separate easily but light prying might be necessary.
  2. How to clean the SAECO Incanto SBS Spout: 步骤 2 中的图像 1,3 How to clean the SAECO Incanto SBS Spout: 步骤 2 中的图像 2,3 How to clean the SAECO Incanto SBS Spout: 步骤 2 中的图像 3,3
    • Remove the spring of the pushbutton. Relaese the Button and remove the black insert off the cup filler.
    • Push off the metal chrome part.
    • Clean it with a small brush and rinse it under water.
  3. How to clean the SAECO Incanto SBS Spout: 步骤 3 中的图像 1,2 How to clean the SAECO Incanto SBS Spout: 步骤 3 中的图像 2,2
    • Reinstall the metal part on the back cup filler part then insert the black piece.
    • Hold up the black part a little for pushing in the Button.
    • Then click it trogether and push in the spring.
  4. How to clean the SAECO Incanto SBS Spout: 步骤 4 中的图像 1,2 How to clean the SAECO Incanto SBS Spout: 步骤 4 中的图像 2,2
    • Click it together, put in the two screws and you are done. :)
结论
3等其他人完成本指南。
Schwarzstein
于07/15/13注册
2,813 声望
创作了13篇指南
一条评论
I just relocated my Saeco Incanto Classic, there's power in the outlet but no power is going in to the machine. What could be the cause?
Ada Ruzza - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 41
总计 6,082
