跳转到主内容
How to clean the Pentax PZ-10 gears
你所需要的
  1. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: 步骤 1 中的图像 1,2 How to clean the Pentax PZ-10 gears, Removing the Bottom Cover Screws: 步骤 1 中的图像 2,2
    • Place the lens face up to locate the bottom cover.
    • Remove the two 7mm screws using a J0 screwdriver.
    • Remove the six 4.3 mm screws using a J0 screwdriver.
  2. How to clean the Pentax PZ-10 gears, Removing the Bottom Cover: 步骤 2 中的图像 1,1
    • After the screws are removed, the bottom cover should easily pry off.
  3. How to clean the Pentax PZ-10 gears, Accessing Gears: 步骤 3 中的图像 1,2 How to clean the Pentax PZ-10 gears, Accessing Gears: 步骤 3 中的图像 2,2
    • Using a J0 screwdriver, remove the 4mm screw holding the metal plate to expose the gears.
  4. How to clean the Pentax PZ-10 gears, Removing Gear Housing Plate: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, gently remove the metal plate covering the gears.
    • Part of the plate's tab fits into a socket. Try to pivot around it when removing the plate to prevent bending the plate.
    • Be careful with the gears because some may be loose.
  5. How to clean the Pentax PZ-10 gears, Cleaning the Gears: 步骤 5 中的图像 1,2 How to clean the Pentax PZ-10 gears, Cleaning the Gears: 步骤 5 中的图像 2,2
    • Use tweezers to rotate gears or remove any large particles obstructing their rotation.
    • Smaller particles can be cleared using a microfiber cloth only. Other fabrics may leave residual fibers.
结论
另外一个人完成了本指南。
Bryan Sugiarto
于04/20/15注册
252 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 14
总计 903
