简介
If the shutter button of the Canon PowerShot SD780 IS sticks, it could be due to debris or residue inside the camera. This guide will demonstrate how to access the shutter button in order to clean out any unwanted substances.
配件
无需配件。
  1. Make sure to turn off the camera and remove the battery.
    • Make sure to turn off the camera and remove the battery.
  2. Remove the five outermost Phillips  #00 screws from the camera.
    • Remove the five outermost Phillips #00 screws from the camera.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove the front panel of the camera case to expose the top left ribbon cable, and pull the ribbon cable gently to disconnect it from the camera.
    • Remove the front panel of the camera case to expose the top left ribbon cable, and pull the ribbon cable gently to disconnect it from the camera.
  5. Remove the single screw on the far left-hand side of the camera.
    • Remove the single screw on the far left-hand side of the camera.
  6. Carefully pull the case apart.
    • Carefully pull the case apart.
    • The case will detach from the camera in two pieces.
  7. Remove the two screws on the metal plate. This will give you access to the spring inside the metal plate for further cleaning.
    • Remove the two screws on the metal plate. This will give you access to the spring inside the metal plate for further cleaning.
结论
另外一个人完成了本指南。
Arlene Ale
于2014年03月13日注册
455 信誉积分
创作了4篇指南
团队
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 477
