跳转到主内容
How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45
你所需要的
  1. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: 步骤 1 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Battery: 步骤 1 中的图像 2,2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to pry the back panel off.
  3. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 3 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 3 中的图像 2,2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 4 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 4 中的图像 2,2
    • Remove the ribbon cable with a pair of tweezers.
  5. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 5 中的图像 1,1
    • Lift and remove the battery.
  6. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, Fan: 步骤 6 中的图像 1,1
    • Gently peel off the tape from the fan.
  7. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 7 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 7 中的图像 2,2
    • Remove five 5mm screws using a Phillips 0 screwdriver.
    • Remove the two 2mm screws with a Phillips 000 screwdriver.
  8. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 8 中的图像 1,1
    • Disconnect the fan's power cable by pulling upward on the pin connector with a pair of tweezers.
  9. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 9 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 9 中的图像 2,2
    • Grab the sides of the fan assembly and remove it by lifting upwards.
  10. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45, How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 10 中的图像 1,1
    • Remove the tape connected to the fan covering plate.
  11. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 11 中的图像 1,1
    • Gently pull the covering plate from the covering tab.
  12. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 12 中的图像 1,1
    • Remove the covering plate.
  13. How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 13 中的图像 1,2 How to clean the CPU fan on Asus VivoBook Q200E-BHI3T45: 步骤 13 中的图像 2,2
    • From the back, push the fan out of the motor.
    • Clean the fan using a damp cloth, and allow to dry.
结论
Bryann Tan
于09/25/16注册
877 声望
创作了6篇指南
团队
USF Tampa, Team 16-2, Eyestone Fall 2016 USF Tampa, Team 16-2, Eyestone Fall 2016 的会员
USFT-EYESTONE-F16S16G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,337
