跳转到主内容
How to clean the Apple Magic Mouse 2
你所需要的
  1. How to clean the Apple Magic Mouse 2, Wipe Down the Mouse: 步骤 1 中的图像 1,2 How to clean the Apple Magic Mouse 2, Wipe Down the Mouse: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    • Using a soft or microfiber cloth, rub on the glass, laser sensor, and the metal portion of the mouse to remove any dust or smudges.
    • After doing a dry wipe off the outside of the mouse, it is recommended to use isopropyl alcohol to sanitize the mouse. Water can be used as a cleaning alternative too.
    • Make sure to apply the alcohol or water to the cloth and use small amounts when cleaning to ensure the internals of the mouse stay dry.
  2. How to clean the Apple Magic Mouse 2, Cleaning the bottom part of the Mouse: 步骤 2 中的图像 1,2 How to clean the Apple Magic Mouse 2, Cleaning the bottom part of the Mouse: 步骤 2 中的图像 2,2
    • Dirt and debris can build up in the charging port and in between the rubber and the mouse. Constant cleaning can ensure the mouse stays clean and functions well.
    • Using your spudger tool, carefully move the spudger in the grooves of the mouse and rubber. This will help to remove and loosen any debris.
    • Using the flat edge of the spudger, carefully move it around the lightning port to loosen any debris.
    • It is recommended to use canned air to remove any debris from the port, otherwise you can lightly shake the port to remove any loosened debris.
    • Be careful when cleaning the lightning port as there is a risk of damaging the port itself.
终点
7等其他人完成本指南。
Colton Turner
于08/13/22注册
561 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 64
过去 30 天: 246
总计 10,747
